Leaking Nimar
Started by KSund ·
Leaking Nimar
  1. Hello
    I've bought a used, and not much used housing for my Canon 50D.
    Unfortunately it's leaking! After replacing a lot of buttons, testing with toiletpaper I've finelly found the leak!
    But it's a small crack in the plastic!
    Could the housing get repaired? And how could it be done/who does it?
    -Kim-
  2. I don't think you have any chance.
    Maybe for surface work you may be able to fix it with some silicone glue, depending on exactly where the crack is, but I wouldn't feel confident.
    For anything at depth, I am pretty shire there is nothing you can do because of the increasing pressure on the walls of the housing.
    Anyway, its always worth a try to contact Nimar and ask them.
    And if the housing was sold to you leaking I would certainly complaint...
    Good luck
    Completely off topic but maybe it interests you... i am selling my Ikelite for canon 40D/50D
  3. I have contacted the dealer, but i don't have much hope that Nimar would fix it.
    I'm thinking of melting the plastic with a soldering bolt, and then maybe som epoxy after.
    What's the price for your Ikelite?
  4. I didn't think much about it because only now decided to sell... but if Imake everything at less then half price we get:
    Housing
    500£
    8" Dome
    200£
    port for 60mm macro
    50£
    port for 100 macro with manual focus
    100£
    Flash DS 125
    400£ 450£ with ball arm and charger (x2 - 900£)
    Dual sync cord (2 strobes)
    70£
    sync cord
    40£
    sync cord Ike to sea&sea/Inon (no auto ttl)
    40£
    Miscellaneous spares and o-rings
    20£
    That makes a total of 1920£
    So I sell the lot for 1700£, the buyer pays pay pall fees and I pay the postage
  5. Sounds like a great setup, but a little bit expencive for a student like me at the moment. And I needs to wait untill I get an answer from the dealer.
  6. oosantoo: Do you have the "print/liveview" button on your housing?
  7. Hi
    Yes it does. And the electronics have also been updated so they offer full automatic t/l both with canon 40D and canon 50D
