Help with Fisheye FIX 1000 LED
Started by Celia_E ·
  1. Hi guys,
    I have a Fisheye FIX 1000 LED video light that refuses to work properly.
    I am thinking the switch is bad since when rotated it gives a full battery indication and the light indicates it should be working. Beyond that there is nothing happening.
    We were in Truk when it happened and were very lucky to be able to borrow a friend's Sola.
    Anyone know where I could send it for repair?
    Thanks in advance,
    Celia
  2. Hi guys,
    Thanks in advance,
    Celia
    Depending on where you purchased, they may be able to repair.
    Last time, I sent mine to Backscatter, though I actually purchased the light in Singapore.. I believe Reef Photo also repair.
    I sent one to Fisheye in Japan the first time, but the postage is outrageous. They replaced all the internals, but missed a bad o-ring under the switch, and it flooded again.
    Both times, everything covered by warranty.
    Good light, but Intovas are more affordable and, I believe, less prone to failure.
  3. Depending on where you purchased, they may be able to repair.
    Thank you, looks like the light is going to Backscatter...
    I'll take a peek at the Intovas, the Sola 1200 we borrowed was really NICE, just short burn time..
    Dive safe,
    Celia
    Edited by Celia_E
