SOLA 2000 Video lights
Started by Davide DB ·
  • 18Posts
  • 18Replies
  1. Hi,
    I already hijacked the Sola 4000 thread asking informations on these tinyer version so I prefer to start a new one.
    I received a couple of them a week ago. Given that my housing is still on the way I thought to use them as hand held lights on a cave dive.
    Before the dive I charged and I made a first burn test. I immediately noticed a huge battery life difference between the two lights. So I completely discharged (at half power) and recharged them four times. So Now I should get real data on battery life.
    One light lasts exactly 50 minutes (exactly the declared battery life) the other one lasts nearly 70 minutes! While I'm happy with the last one I'm disappointed on the first one: If a brand new battery last exactly 50 minutes I guess that with use, the battery life will shortly decrease under the declared life... In short I cannot return the light because it falls just within the specs!
    While I was recharging the good one I suddendly noticed a strange rumor from the inside. Gently shaking the light I could hear a sound indicating that there is something broken free to move inside, something like a "maracas. Obviously the light never took hits or felt on the floor neither went in water because I tested them only in my kitchen sink. Moreover it's like this object get jammed somewhere inside the light so the sound it's not happening all the times...
    I returned the light at the shop. they opened the light discovering that there is an ultra small electronic component hanging around which detached itself from the small electronic board inside. It's clear that this component should have been soldered and it's very unlike that a hit could have caused the detachment.
    So they sent back the light to the Italian importer and give me back a brand new light. Nothing could be made for the other light.
    I still have to express a judgement on this product except that a better checking and test process before leaving the factory would be advisable. They proudly write on the light case "assembled in USA". Maybe at Foxconn they do a better job? :)
    Bye
  2. 'One light lasts exactly 50 minutes (exactly the declared battery life) the other one lasts nearly 70 minutes! While I'm happy with the last one I'm disappointed on the first one: If a brand new battery last exactly 50 minutes I guess that with use, the battery life will shortly decrease under the declared life... In short I cannot return the light because it falls just within the specs!'
    So are you saying that you are not happy because the light lasts for exactly the advertised time? Seems a bit odd to me considering you bought the lights knowing exactly what the specs are & now when you get them you are not happy with that????
    Cheers Pete.
  3. So are you saying that you are not happy because the light lasts for exactly the advertised time? Seems a bit odd to me considering you bought the lights knowing exactly what the specs are & now when you get them you are not happy with that????
    Hi Pete,
    don't misunderstand me, I'm just saying that if a brand new battery just last exactly 50 minutes, that is the target burn time, within a short use period it will last less. I use a lot of dive lights and scooters for cave diving so burn time it's a must. This is one of the few times I see a battery durinng exactly the time the producer declare. At the same time it's strange seeing another light lasting 70 minutes.
    Probably in a few dozen dives it will last 45 or 40 minutes. That's it.
    For the other light no excuse
  4. don't misunderstand me, I'm just saying that if a brand new battery just last exactly 50 minutes, that is the target burn time, within a short use period it will last less.
    I've usually found that, with the newer technology batteries, over the first few cycles, the battery life gets a bit longer, then it settles at that burn duration for somewhere between 50 to 150 cycles before it starts reducing.
    With my 4000s, I run them on power setting 1 for navigation then bump them up to mid or high power depending on the needs of the shot. Lasts plenty of time.
    Regards
    Peter
  5. I've usually found that, with the newer technology batteries, over the first few cycles, the battery life gets a bit longer, then it settles at that burn duration for somewhere between 50 to 150 cycles before it starts reducing.
    Ok, I will see how it will gets.
    In the meantime I received a brand new light as replacement for the broken one.
    Bye
    Edited by M43user
  6. I recently took delivery of a couple of Sola 2000 lights and gave them their first workout over the Easter long weekend at the local shore dives in Nelson Bay.
    Overall I'm very happy with them - they are quite an improvement on the Inon 500 lumen lights I was using.
    Here is a clip their first outing.
    EDIT Fixed it up for you. Wagsy
    Edited by wagsy
  7. It looks like I screwed up tyring to embed the video
    here is the link
    Edited by wagsy
  8. Nice footage Steve. The colours are great also.
    Nelson bay is such good diving.
    Looking forward to some more videos mate.
    Cheers Pete.
  9. Nice footage Steve. The colours are great also.
    Cheers Pete.
    Pete
    It was good to see you at pipeline - hope to meet again some time
  10. Definately was good to meet you Steve.
    Do you live up that way? I try to get up there as much as possible but it is never often enough.
    I have just edited another video so will have that up either tonight or tomorrow.
    By the way, what camera do you use?
    Cheers Pete.
  11. I recently took delivery of a couple of Sola 2000 lights and gave them their first workout over the Easter long weekend at the local shore dives in Nelson Bay.
    Awesome clip Steve! What Cam/housing are you using??
    Greg
    Edited by sideways
  12. Awesome clip Steve! What Cam/housing are you using??
    Greg
    Greg
    It's a canon HF G10 in a Bluefin Pro Housing.
  13. Greg
    Im looking at buying the Canon HF S30 w/ Bluefin housing. That gives me a perfect example of the cams capabilities. Thanks Steve!!
    Greg
  14. Im looking at buying the Canon HF S30 w/ Bluefin housing. That gives me a perfect example of the cams capabilities. Thanks Steve!!
    Greg
    Hey Greg
    I have Eric Cheng's Bluefin here. He left it on his way back from Indo trip. Its for Canon S30 and G10. Try and PM Eric as I think he wants to sell it. Comes with a handle which I have made and some XIT 404 stuff.
    David
    Sorry Ed. if this need to go to the classify then let me know...cheers
  15. I really enjoyed that video Steve. Looks like a very interesting place to dive.
  16. Hey Greg
    David
    Thanks David! I sent Eric a PM :) To the OP, sorry for the threadjacking :)
  17. Definately was good to meet you Steve.
    Cheers Pete.
    Pete
    I live at maitland so I am at Nelson Bay most weekends.
    I'll keep an eye out for you.
    Cheers Steve
  18. I may be moving up to the central coast soon so i could be a regular visitor up that way.
    Cheers Pete.
