Frog Fish
Comments/critique welcomed.
Nice Mug-shot Bill, but the focus seems 1/2" too far back (Soft). A slight adjustment in contrast levels may remove a slight cast also.
Bob
Hello Bill,
Nice shot. You included the face and some of the side. Much more pleasing than a simple side shot. And, its framed vertically, which is also right on. I would have composed it a bit differently however by trying to gain a slight upward shooting angle, or at the least, eye level. Of course, with some subjects, especially frogfish, you do not have many options unless you are a contortionist. :-) So, forgive me if that was the case in this situation.
Also, it appears either you used only one strobe or your left strobe was blocked as the primary side of the frogfish is not lighted. If you had only one strobe, I would have positioned it on the left side. If you were using two, it was just one of those cases where it either did not fire or it could have been positioned better. Shaded areas can be pleasing in an image, but usually not when so much of the area of the image is involved.
Scott
I'll post this one as it's an almost identical pose, and taken with just one YS 60.
Bob,
Your shot illustrates the points I was trying to convey. The improved shooting angle opens the mouth and levels the eye for the viewer. And, the shadows, which are on the secondary or exterior side of the subject, highlight the frogfish. Good shot.
Scott
