Light and Motion D200 Dome port wanted
Started by Nobubblediver ·
  1. Hi I'm after a Light and Motion dome port fisheye if possible or conversion rings so that I can use Sea & Sea dome port.
    Does anyone have a dome port or rings they no longer need, or know where I can get my hands on one?
  2. Hi I'm after a Light and Motion dome port fisheye if possible or conversion rings so that I can use Sea & Sea dome port.
    I have a Titan 100 with an eight inch glass dome. I am not sure if you it can be used with 180 degree fisheye lens, the hood is built into the port. I will sell the port with the housing for $ 650.00. The housing without the port makes it useless for me. Unless someone out has a L&M flat port.
  3. Hi I'm after a Light and Motion dome port fisheye if possible or conversion rings so that I can use Sea & Sea dome port.
