Subal D7000 lens/dome port combination
Started by foto-diver ·
  1. I have a a Nikon D7000 in a Subal housing. My experience with wide angle has only been wide angle close up with a Tokina 10-17 w/1.4 tele behind a Zen 4" dome. I'm headed for Cocos Is in May and have concerns that my current wide angle combination is not the best for what I will encounter at Cocos Is. I will be using two S&S YS-250s.
    I would appreciate any recommendations on dome port/lens combinations that would be best for the longer range, larger subjects and reduced lighting I will most like encounter at Cocos Island. It's my understanding that it will be very difficult to close in shots of the schooling and individual larger subjects with a standard regulator.
    I have done a search on this site with mixed and some outdated advice.
    Thank you,
    David
  2. Hi David,
    I had some luck with the 10-17 and the little Zen Dome on my 7D and YS-250's at Cocos last summer. You're right that the hammers really don't like the bubbles so while I can't recommend you hold you're breath, it does help if you breath really slowly at the appropriate time.
    Both of these were shot at the 17mm end of the lens.
    You can see some more images with the setup on the flickr page.
  3. Thank you Steve.
    Were you using a tele on the 10-17?
    What ISO did you use?
    I know you a Canon guy, but the basic concepts in lenses are the same. Your thoughts on an f2.8 vs an f4.0 lens in this type of shooting.
    David
  4. Were you using a tele on the 10-17?
    David
    No tele on the Tokina David, typical for the somewhat dark,(rainy season) deep Cocos, I was using ISO200. Jump setting was F 7.1 at 125th.
