Mixing strobe arm standards
Started by oskar ·
  1. Hi,
    I have the opportunity to by a nice set of carbon fiber arms at a good price, but they have "European standard" 24mm ball ends. Will those match 25mm/1" items like the YS-ball converter i need for my YS110 strobes?
    Will they work seamless or could they become wobbly?
    /O
    Edited by oskar
  2. I doesn't work well, 1" clamps will not work on the 24mm ball ,also the clamps with the o-rings that i am using do not fit good.
  3. Ouch, back to the drawing board then.
    Doesn't the oring on the ball even out the difference somewhat?
    Is there a YS-ball 24 adapter available?
    /O
  4. I mixed 1" balls with o-rings (on my tray/handles) with a Sea & Sea Arm VII arms and clamps on dual YS-110a strobes. The Sea & Sea balls are bigger and the clamps grab at a slight angle. Been using them 3-4 times a week for 6 months with no issues.
    The Sea & Sea tray that came with the arms sucked and I replaced it with another that has built-in 1" balls on top of the handles. Everyone told me it wouldn't work (my friends at Reef were adamant about this - LOL!) and I would have to spend and additional $400+ on a set of new arms...... I tried it anyways and see no problems at all..... if anything, the bolt on the clamp sees a bit more stress from the angle, but that's it. I can tighten them enough to not move either on land or underwater without having to crank them too much more than before.
    My advice: Try it first before you plunk down more money.
