Using Unsharp Mask with scanned slides
Started by scubamarli ·
  1. Using Unsharp Mask with scanned slides
    Forgive me if this has been discussed before, but I couldn't find anything definitive. Are there any basic starting points for using Unsharp mask? I am scanning slides using a Nikon Coolscan IV. I don't want to add too much "grain". Is it just a matter of trial and error. I'm scanning for publication, if that helps.
    Marli
  2. Don't do any sharpening during the scan. Do it all in Photoshop.
    If you are familiar with PS, then use an adjustment layer/mask. Blue water doesn't sharpen well without adding "noise". There are some tutuorials on USM out there somewhere.
    Do not sharpen until the end, meaning you are done with other adjustments and the image is sized to final output. If your final ouptut is CMYK printing, then sharpen the crap out it. It should look crunchy on your screen.
