Using several extension rings instead of one?
Started by MortenHansen ·
  • 11Posts
  • 11Replies
  1. Hello everyone.
    I have a friend (fellow photographer) coming to visit me here in Tulamben, Bali, at the end of the month and I was thinking about getting him to bring a Kenko 1.4 teleconverter to do some super-macro work with my 7D.
    Gear that I'm using:
    Aquatica A7D housing w. Aquatica Af/Mf flatport+extension and a 100mm f2.8 USM Macro
    Now the questions are:
    1) How much would I have to extend my port for it?
    2) Does any of you have experience/suggestion using 2x "small" extension rings instead of one big? (thinking I can save the money needed to buy another bigger extension-ring)
    3) I realize that dome-ports have to have a certain distance to the lens to assure optical quality, does this also go for flat-ports w. macro lenses? (I guess not?)
    Thanks for the feedback, Morten L. Hansen
    Edited by MortenHansen
  2. Hello everyone.
    I think that the Kenko PRO 1.4 is about 23 mm long (maybe 24, someone has borrowed mine so I can't measure it right now but I have it written down as 23.5). I often use two exensions but remember that means two seals that could leak. In practice to get teh maximum
    magnification your lens should be within a few mm of the port.
    Bill
  3. 1) I don't know
    2) I have done this in the past. I paint a line on all my ports and extensions (started before the body port lock existed). This way I know all my ports are on tight. I don't know all the dimensions.
    3) If the combination is too short, the lens will hit or rack into the glass. This is very bad. If it doesn't touch and is a little long, it will be find. If it is way too long, then will lose some ability to get close, but it is still functional. I doubt it will be to long unless one of your extensions is fairly long.
    Come to think of it, I've strung 3 extensions together. Lots of failure points.
  4. 1) How much would I have to extend my port for it?
    Just enough to be sure that the lens doesn't crash into the end of the port. My tele-converter is 19MM long.
    Just more leak points and probably not as strong, not suggested.
    This only applies to dome ports.
  5. Hi I have an aquatica part 18463 extension for sale. That might be the closest extension for size. It is in excellent condition. I would like $150usd plus shipping.
    18463
    EXTENSION RING
    21.5 mm / .82” (overall 34 mm / 1.32”)
  6. Hi I have an aquatica part 18463 extension for sale. That might be the closest extension for size. It is in excellent condition. I would like $150usd plus shipping.
    18463
    EXTENSION RING
    Thanks for the feedback!
    And thanks for the offer, however it would not be an option for me to get anything sent, I am living in Indonesia and the postal service is less than reliable :lol: I will pick up an extension ring and the Kenko next time I drop by Singapore :)
  7. Hi I have an aquatica part 18463 extension for sale. That might be the closest extension for size. It is in excellent condition. I would like $150usd plus shipping.
    18463
    EXTENSION RING
    I looking for a 18462 (39.5 mm / 1.56”) Aquatica ext. ring if anyone has one they'd like to part with.
  8. I will pick up an extension ring and the Kenko next time I drop by Singapore :lol:
    Yup... I kinda dropped the ball on that one, but I couldn't find them ANYWHERE.
    Looking for a Kenko/tamron teleconverter here in Bangkok is like searching for an honest politician.
    Does anyone know why that might be? Am I not looking in the right places?
  9. Looking for a Kenko/tamron teleconverter here in Bangkok is like searching for an honest politician.
    Don't look in the US Congress.
  10. Yup... I kinda dropped the ball on that one, but I couldn't find them ANYWHERE.
    Quick Camera is the Tamron Distributor in Bangkok, (quickcamera.co@gmail.com) they should be able to tell you where to get one
    Bill
  11. Quick Camera is the Tamron Distributor in Bangkok, (quickcamera.co@gmail.com) they should be able to tell you where to get one
    Bill
    Cheers Bill!
    They didn't respond to my email, but I found one through Niks Thailand.
