Storing Low Discharge Batteries. Refrigerator or not?
Started by mcgowman ·
  1. Is there any advantage to storing LSD NiMH/Eneloop type batteries in the refridgerator?
  2. In my experience, storing NiMH batteries at anything but room temperature will generally not benefit you. Cold temperatures will reduce a battery's performance, but not its self-discharge rate.
    As far as I'm aware, storing NiMH batteries at 50-100% charge at room temperature is best for them.
  3. In my experience, storing NiMH batteries at anything but room temperature will generally not benefit you. Cold temperatures will reduce a battery's performance, but not its self-discharge rate.
    Self discharge is governed by the Arrhenius equations and normal NiMH self discharge is quite temperature dependent. The envelop type batteries have such a low discharge rate that reducing it by half or more (factor of 2 for 10 degrees C) will not change the storage time very much. If you lose 3% per month and that goes to 1.5% per month you are not gaining a lot. Put beer in the fridge instead (its half life will be a lot shorter, I guess).
    Bill
  4. Thanks all.
  5. The best way to prevent self-discharge on ANY battery: Discharge daily under load..... <<DIVE OFTEN>>
    Sorry, I couldn't resist that...
