Cross-threading 67mm
Started by agshep ·
  1. I need simple instructions for attaching lenses to the front of my Ikelite box for a Nikon p5100.
    It seems odd that Ikelite make such a fine thread in nylon when every attachment is metal.
    Cross-threading seems inevitable if I haven't already.
    Any thoughts on how to avoid it- there isn't a definite click or orientation when turning counter-clockwise and I'm most certainly not going to try this underwater...
  2. I always screw things backwards until I feel them catch then
    I screw in normal direction.
  3. I put grease on the threads for less friction and wearing out.
  4. I always screw things backwards until I feel them catch then
    Yes, that is the way to do it with any tread, but especially with treads of plastic or very fine treads.
    Screwing backwards gives you a tactile feeling that the tread locked in place and is safe to screw on.
    I don't think that grease is a good solution as it may aggravet the problem of cross-treading as the necessary
    force for screw in it on - either right orwrong - will be reduced and second the grease may get on the lens with a terrific
    impact on the pictures.
    Chris
  5. I noticed that problem as well. I have just been as careful as possible, stopping straight away when you notice it is not in the right tracks. I was scared of slicing the nylon threads of the housing off, but after more than one year (of a steady few dives a week) and a loooot of changing lenses everything still works OK luckily.
