Port Recommendation for 60mm + 1.4x teleconverter
Started by DivePalau ·
  1. Good Morning,
    I have a Nikon D90 /w Ikelite housing. I need to buy a port for my Nikon 60mm /w tamron 1.4x teleconverter.
    What acrylic port do I need to buy to house this combination? I was thinking a 105mm port. Would that be the right choice?
    Chris Christensen
  2. The Ikelite chart says 60mm Macro D 60mm Macro f/2.8G ED AF-S Standard - Flat port — 5502.41 port #5502.41 Lens less than 4.1" (10.4cm) ... $150
    Your tele converter should add about .75" or 19mm to the length so I would think the idel port would be #5505.45 Lens less than 5.1" (13.0cm) ... $150
    However you can use anything longer as the view of the lens will not see the port but you will have additional size and buoyancy.
    #5501..... Lens less than 2.5" (6.30cm) ... $125
    #5502..... Lens less than 3.5" (8.90cm) ... $125
    #5505..... Lens less than 4.5" (11.4cm) ... $150
    #5505.5.. Lens less than 5.5" (14.0cm) ... $150
    #5505.58 Lens less than 6.1" (15.5cm) ... $150
    Haye a great day
  3. Thank you for the help. I'll take a look at it!
    Haye a great day
  4. My 60mm D lens and 1.4x teleconverter fit perfectly in the port for my 105mm D lens.
  5. I assume there isn't a port that allows manual focus for my lens? I see this for the 105mm D:
    105mm Macro D
    Standard - Flat with Focus
    Requires:
    — 5508.05 port
    Allows switching between manual and auto focus underwater. $$
