Port recommendation for Tokina fisheye 10-17
Started by DivePalau ·
  1. Hello Everyone,
    I got such good advice from my last post I thought I'd ask one more question.
    I am getting a Tokina 10-17 fisheye for my Nikon D90. I have a 1.4x teleconverter that I bought for my nikon 60mm lens, but is it worth using the teleconverter on the tokina?
    What Ikelite port should I buy for my tokina? Should I factor in the teleconverter or buy a port for the tokina without the teleconverter?
    Chris Christensen
  2. I have had very good luck and results with the D90, tokina 10-17 and a tele-converter in a ilelite housing with a mini dome. The tele-converter allows you to use the wide angle lens but has a smaller field of view so it works great for smaller subjects. The tele-converter will add about 19mm or .75" to the length of the required port.
  3. What kind of teleconverter do you use?
  4. I use the 4.3" Bare Dome with a Kenko Pro 1.4x TC. Another TC may not work with the Tokina.
    Bob
    Edited by Deep6
  5. is there anyway of using the lens with TC with the 6 or 8 inch Ikelite domes?
  6. is there anyway of using the lens with TC with the 6 or 8 inch Ikelite domes?
    Sure you can use the teleconverter with the 6" or 8" dome. For the six inch you will need one that is 3/4" or 19mm longer than what ikelite recomends. For the 8" you will need a longer port.
  7. I use the 4.3" Bare Dome with a Kenko Pro 1.4x TC. Another TC may not work with the Tokina.
    Bob
    Bob That is a great dome but Barry dosen't make one for the ikelite housing and I believe that is what the orgional posted has. You can find the same dome for the ikelite housing on the left side of bary's page http://www.bareports.com/index.htm
