Nofilmshool released a video comparing the 5D3 against the predecessor 5D2 and king of MP, D800. The FOV of the D800 is cropped from the FF sensor, ostensibly because of the high pixel count and downsampling ratio. Basically it's 91% of the full width, so FOV on the widest lens will be 9% narrower.
Anyhow, note that the comparison is a bit skewed. The D800 allowed 422 uncompressed capture via HDMI and that's what was used in the comparison. The 5D3 used ALL-I processed in 5DtoRGB at REC709. Strangely the 5D2 was processed at REC601. It's obvious that the resolution from 422 uncompressed is nice but the noise is pretty bad. I'd say over 2.5 stops because there's no compression and noise reduction incamera for the D800.
[vimeohd]40113110[/vimeohd]
What's amazing is that at ISO25600, the candle looks like a 100W bulb!!! That's seeing in the dark!!!
