Question on Ikelite Substrobes MS and 150
Started by NJBeachdiver ·
  1. Question on Ikelite Substrobes MS and 150
    I'm planning on buying an Olympus C5060 with the PT-020 housing. Can I use both or either of the 2 stobes I already own ( Ikelite MS & 150 )with this camera? If I can what cables etc will I need to buy. If I cannot use them what choices do I have ?
  2. You can use them in manual mode with the 5060 I think. The Ms will fire a full power dump every time and I think the 150 has Full and 1/4 power settings. TTL will not work with the setup.
    HTH
    James Wiseman
