Nautican 7D shutter is totally loose (help?)
Started by echeng ·
  1. Hello, all. The spring on my Nauticam 7D shutter broke on my last trip, but the shutter still worked—I just had to back it off manually between shots, which I got used to quickly. However, I lent the housing to a friend, and while he was pool testing it, he heard a "loud click" while activating the shutter, and after that, the shutter started behaving very strangely.
    Here's the description:
    I was taking pictures and pushing the shutter release back away after each shot as you instructed, but one time when i pushed it back i heard a loud click and then the shutter release didn't work properly anymore after that. I could get it to work again after fiddling with it and pushing it forward and back, but not it could go too far forward and back. i am not sure exactly what is happening when it does start working again though.
    Here a video of the shutter:
    Does anyone know if there is a service center in Los Angeles that can take a look at this TODAY? He's leaving tomorrow for Palau...
    Thank you!
  2. Hi Eric,
    Can you have him send a pic of the internal part of the shutter mechanism to us at innovation@nauticamusa.com? Possible we can walk him through adjusting it but the "loud click" might indicate otherwise.
    Regards,
    Cp
    Edited by Cp
  3. I had a problem with my shutter control shaft coming lose on my Naticam 7D housing during dives. I had to take apart one of the housing gear mechanisms to tighten a tiny screw at the end of the shutter control shaft. After doing this a few times, I finally put some blue loctite on that little screw and I haven't had any issues with it over the past 18 months.
  4. With both my NA-7Ds I found that the length of some of the set screws was too short and only engaged for less than two turns with the threaded holes. I identified appropriate and longer replacements on Ebay. Could it be the loud click you experienced was caused by leverage impinging on the short stock screws?
