Flash unit for Aquatica A300 Housing
Started by rpf111 ·
  1. Flash unit for Aquatica A300 Housing
    Any ideas on a flash unit to use with this housing?Thanks
  2. Any ideas on a flash unit to use with this housing?Thanks
    As far as I know, Aquatica is working on a TTL converter that will allow the use of "off the shelf" unit using standard Nikonos TTL protocol. You should drop a line to Aquatica ( info@aquatica.ca ) to follow up on this progress.
    Jean Bruneau
