Port Chart for Nauticam 7D + Canon 8-15 fisheye
Started by kannjihyun ·
  1. I noticed that Nauticam hasn't updated Canon's port chart for the newly released 8-15 fisheye lens yet. I'm using Tokina with 8.5" dome + 20mm extension ring now. Do you think this same port set would work with the Canon 8-15 fisheye?
  2. I noticed that Nauticam hasn't updated Canon's port chart for the newly released 8-15 fisheye lens yet. I'm using Tokina with 8.5" dome + 20mm extension ring now. Do you think this same port set would work with the Canon 8-15 fisheye?
    30mm of extension is recommended, but you'd likely not be able to see the difference between 20mm and 30mm in the 8.5 dome.
  3. 30mm of extension is recommended, but you'd likely not be able to see the difference between 20mm and 30mm in the 8.5 dome.
    Hi Ryan,
    Thanks for your reply!
    So... The 20mm extension dome will be working fine as well? Why would the 30mm work better then the 20mm?
  4. So... The 20mm extension dome will be working fine as well? Why would the 30mm work better then the 20mm?
    30mm is recommended, but you could certainly test the 20mm and see fi the image quality meets your needs. These things are somewhat subjective.
    More info here:
    http://wetpixel.com/i.php/full/dome-theory/
