Ikelite 6038.53, Sony CX550 and heaps of extras!!
Started by lukes ·
  1. Hi guys,
    I'm selling my underwater filming kit on ebay. Here's the link:
    http://www.ebay.com/itm/Ikelite-6038-53-So...#ht_1567wt_1378
    I haven't used it much...only about 10 times. That's why I'm selling it.
    It contains camera, housing, rain cape, lens filters, spare batteries, camera bag and heaps of spare parts.
    Good luck bidding.
    Best regards,
    Luke
    DETAILS:
    Underwater housing:
    Ikelite housing #6038.53
    Colour filter #6441.41
    Lens cap
    2x spare o-rings #0109
    Spare control tips #9249
    Specifications:
    - Optical Glass Port
    - Power on/off Control (through circuitry)
    - Record start/stop
    - Zoom Control
    - Snapshot Control
    - Mode Button
    - LCD Touch Screen (3 controls)
    - Image Reversing Circuitry: The image in the view mirror appears true; right is right and left is left.
    - Removable External UR/Pro Filter
    11" wide x 8" high x 8.25" deep including base and handle assembly.
    27cm x 20cm x 21cm.
    8.1lb (3.7kg) above water.
    Slightly negative in saltwater for stability.
    Please check out the manufacturers site for all details:
    http://www.ikelite.com/web_two/sony_cx550.html
    Camcorder:
    Sony HDR-CX550V Full HD 1080
    Exmor CMOS sensor
    64GB internal memory + SD slot for even more memory
    2x NP-FV100 batteries
    NP-FV50 battery
    BC-TRV charger
    Tiffen 37mm UV Filter
    Tiffen 37mm Polarizing filter
    All cables
    Samsonite case with detachable bottom compartment
    Remote control
    http://store.sony.com/webapp/wcs/stores/se...umber=HDRCX550V
    Rain Cape:
    Ewamarine VC-1S
    Alu adapter ring 30mm-49mm
    Alu adapter ring 37mm-52mm
    2x cape adapter ring
    Cape click in ring
    The VC-1S is a rain cape for the current smaller camcorders.
    The camera is attached to the front port, by means of an ewa-marine C-A52 adapter. This patented system attaches the cape to the camcorder and holds the front port in front of the lens like an optional, clear filter.
    Due to the new design, it is now possible to open a flap on the cape in order to use the cameras LCD-monitor. This ideal for tripod operation.
    The VC-1S rain cape is manufactured from special PVC and has an integrated, optically neutral flat glass port. It can be closed by means of press-studs at the bottom.
    This rain cape is designed for small camcorders like for example the Sony HDR-CX550V or other similar camcorder models till a maximum length of 15cm ( 5,9 inches).
