TTL setting for Subal D200 / Inon Z240
Started by magicfx ·
  • 10Posts
  • 10Replies
  1. How to set Subal D200 to TTL mode?
    Is my "No.2/No.4 configuration" the right setting?
    Should I set Inon Z240 to STTL or Auto mode?
    What's the difference?
  2. I think you are having a misunderstanding because the Inon Z240 does not work in TTL with the D200 whatever the setting. You would need a TTL converter or shooting through optical fiber in order to have TTL.
  3. Does exist a TTL converter for Inon Z240? I mean not using optical fiber but only the sync cord. Anyone has tried the Sea&Sea TTL converter with Inon?
  4. Does exist a TTL converter for Inon Z240? I mean not using optical fiber but only the sync cord. Anyone has tried the Sea&Sea TTL converter with Inon?
    Yes, I have used a Sea & Sea TTL converter, type N with a D 200 and the same converter with a D2Xs. Please be aware that there are different Sea & Sea converters. The converters needs to match your camera model and strobe. I believe they all work with either a Sea & Sea strobe or a Inon strobe. Contact Ryan at Reef Photo, he will guide you accordingly.
    Edited by eyu
  5. Yes, I have used a Sea & Sea TTL converter, type N with a D 200 and the same converter with a D2Xs. Please be aware that there are different Sea & Sea converters. The converters needs to match your camera model and strobe. I believe they all work with either a Sea & Sea strobe or a Inon strobe. Contact Ryan at Reef Photo, he will guide you accordingly.
    http://www.seaandsea.jp/products/digital_s...essory/008.html
    I saw only these 2 type:
    YS Converter/N
    and
    YS Converter/C
    Does YS Converter/N work perfectly with Nikon D200 and Inon Z240 type4?
  6. Does YS Converter/N work perfectly with Nikon D200 and Inon Z240 type4?
    Sea & Sea has made different iterations of the type N convert as new Nikon models have come out. I do not know if a new type N will work with an older body like the D 200. Ask Reef Photo or Sea & Sea.
    Edited by eyu
  7. I shot the Nikon D200 with Inon 240 and S & S TTL converter.
    I believe the person who bought my equipment is not using it.
    Are you interested in it?
    P/M me if interested.
  8. I shot the Nikon D200 with Inon 240 and S & S TTL converter.
    Subal housing is with S6-type plug
    but Sea & Sea is with another type.
    Any TTL converter with S6 plug on the market?
  9. Subal housing is with S6-type plug
    The ones I user had Nikonos 5 plugs.
  10. Subal housing is with S6-type plug
    You can exchange your S6 bulkheads to a Nikonos 5 pin to work with Sea & Sea sync cords. Besides Sea & Sea TTL's look at Heinrich TTL's.
