I was wondering if anyone know if it is possible to somehow connect an extern monitor to the Sea and Sea D7 Canon housing.
Would it be possible to connect or change one of the adapter so it is possible to use it with some kind of bulkhead for a Monitor.
Søren
I remember S&S had a 4:3 monitor for their video housings using component connectors. Not sure if they still make those any more.
Other alternatives include the Backscatter Wahoo monitor, which I'm sure can be modified to fit a S&S housing. Also Nauticam has a SmallHD DP4 housing which you can look at. Both use mini-HDMI. The only issue I can think of is that the S&S housing may not have the space to fit the HDMI plug.
Hi Drew,
Thanks for the answer. Yeah have looked a little around and looks like i have to modify the bulkhead to a HDMI.
