Manual on Ikelite housing
Started by seansrs968 ·
  1. When shooting WA I do not use the TTL mode on my strobes. I usually reduce the strobe power on the strobe itself. My question is do I have to do this also on the back of the housing.
    Sean
  2. Hi Sean
    If you move the strobe knobs from the TTL position, they go into manual mode.
    Having a tendancy to use strobes on long arms, I find it a lot quicker to leave the strobe knobs on TTL and adust power using the manual control on the back of the housing - unless I need a different power on each side.
