New Panasonic G5 announced
Started by Davide DB ·
  1. The new G5 has been announced.
    http://www.dpreview.com/previews/panasonic-lumix-dmc-g5
    While I'm sure that we will never see a uw housing for this camera. I'm sure that most of the features will be present in the upcoming GH3.
    I think that if Panny doesn't make a false step, it will rule 'em all again wink.png
    Rumours on the GH3 says that it will be water sealed as the latest power zoom lens.
    A new sensor is arriving and finally we have the 1080/50/60 (28Mb on G5)
    The most interesting is the second small lever near the shutter button that can be programmed for zoom or aperture.
    On the G5 all rumors pointed towards it having the same G3 sensor, but instead it has an improved one seemingly based on the GH2's technology.
    So lets count some of the imrpovements:
    1) Return of the EVF proximity sensor
    2) Larger, more comfortable hand grip at nary a size expense.
    3) Higher Res LCD(920k dots vs 460k)
    4) Programmable Function Lever, can be used for powerzoom or exposure compensation/aperture changes). Essentially like having a second dial.
    5) 1 additional programmable function button, AF/AE button, better button placement
    6) More clicky buttons with better build
    7) 9 more Art modes, if you're into that type of thing
    8) 6fps at full res, vs 4fps. 3.7 fps with continuous AF
    9) Can continue to shoot and access menus with a full buffer
    10) Control the AF point using the touchscreen as touchpad while using EVF! Seems super useful.
    11) 1080p60, at 28mbps! Real slow-mo footage possible.
    12) Improved battery life rating(320 vs 270, uses GH2 battery)
    13) New, Multi-aspect-ratio sensor(This might not seem significant, but is actually very useful when shooting in aspect ratios other than 4:3, particularly for wide-angle lenses.). 18.3 total megapixels vs 16.8. On-chip processing.
    14) Iso 12,800
    15) 3 frame HDR mode
    Edited by M43user
  2. M43 user,
    Press photos of this equipment can be found at Panasonic, using the DPReview photos that have the copyright logo right in the frame is highly inappropriate. I am sure you would not want anyone using your photos and video without permission.
    Phil Rudin
  3. M43 user,
    Phil Rudin
    Ok I removed the dpreview photos.
    Comparing my post to use my photos and video without permission is a bit stretched. Anyway I removed them
