YS-D1 strobe incompatible with Ikelite housing
Started by edmond320 ·
  1. Hi dear all,
    I have brought two Sea & Sea YS-D1 strobe. Using Ikelite sync cord, I have connected the YS-D1 strobes with the Ikelite housing for Sony A55.
    Unfortunately, the 2 YS-D1 strobe do not respond.
    If I connected the housing with YS-110A or Ikelite strobe, the strobe fire accordingly.
    So obviously, the new YS-01 stroble is incompatible with Ikelite housing,with the existing sync cord.
    Is Ikelite going to make a new sync cord for YS-01 ??
    Can anyone help and advice?
    Thank you very much in advance and appreciated !!
    Edmond Chan
  2. That seems odd; I was under the impression that the D1 used the same electrical sync signals as the 110a. The fact that it works with a standard Nikonos cord on S&S housings suggests that the pinout is the same.
    Bill
  3. Did you have the switch in the right position? You should be in Manual, not Slave or TTL.
    S.
