Olympus PT-010 DIY Cleaning Guide...
Started by sehsuan ·
  1. Olympus PT-010 DIY Cleaning Guide...
    I just did a cleaning of the casing by myself, and did a tutorial for those interested in how the PT010 is constructed. I've yet to test out the casing at pressure at a nearby swimming pool to see if the sealing of the black O-rings are intact, but i'll keep you guys posted!
    Wait no longer, here is the article!
    http://sehsuan.clubsnap.org/olympus/
    Disclaimer: I'm not responsible for anything! ;)
  2. Great stuff! I think I'll get started right away. That will keep my mind off ideas about getting new and expensive gear. Or maybe I should wait for your pool test... :)
  3. paste, i tried it out in the swimming pool in my institute, it's only a 1.8 meter deep test though. no problems. :)
  4. Where did you get the new o-rings? :?:
  5. Then I shall get to it! Those black o-rings look a bit salty. :)
  6. meister, i did not purchase new black O-rings. i took mine out carefully using a screwdriver, in a similar way you'd gently take a poached egg off a hot pan. :)
    paste, please be careful!
    my friend on another forum has shown me another site, http://pt010.da-kine.info/topics.htm , which has cautioned especially when doing the zoom lever - because if the lock "bolt" is not fastened into the groove, there is a risk of flood! :(
  7. How often do you service your housing this extensively?
