Manual Focus Gear for 60mm?
Started by gee13 ·
  1. Just thought Id ask how many folks on here actually use a manual focus gear for their macro work. Been interested to know - Im only using AF atm but wondering how much more one can achieve in terms of advantages of having the facility for manual control underwater with small subjects?
  2. I shoot a lot of macro. I don't shoot the 60 much, preferring the 105mm. I have focus gears for both, and they sit in a bag.
    The one use I consider is when using a teleconverter or a wetlens, like a Subsee. I tend to use the Focus lock button, even then.
    Marli
  3. I shoot a lot of macro. I don't shoot the 60 much, preferring the 105mm. I have focus gears for both, and they sit in a bag.
    Marli
    Marli,
    I have a 5D MII and would be interested in how do you apply the use of the Focus Lock Button. Do you have it programmed so that instead of pressing halfway down on the shutter button do use the focus button instead? Canon's user manual is not very good at explaining when and how to best use this the focus button. I hear that people use it quite a bit once they learn how to use it properly.
    The Meltdownman
  4. I shoot Nikon; sorry. I focus using the shutter button and just hold the lever down on my Aquatica housing, and then sort of float back and forth. I generally only use it when having difficulty auto-focusing.
  5. Custom menu function IV-1, option 2 or 3 depending if you want to use AF-ON or AE-Lock button
    I use back button focus on my Nikon, because I couldn't feel half press on my housing and couldn't hold focus lock when crap in the water moved into the focus area.
  6. Thanks folks would like to hear more thoughts, so the concensus so far is for focus lock on AF? Just FYI I use a Canon T2i/550D. WOnder if theres a facility for this. Housing is Aquatica btw.
    Im already doing the rocking back and forth but wondering if trying to stay a little more staionary and use the manual focus gears. That said uw its pretty hard to stay stationary anyway unless maybe if you have a tripod to assist.
  7. Marli,
    The Meltdownman
    You might want to have a look here. http://cpn.canon-europe.com/content/education/technical/eos_5d_custom_functions_explained.do
    and this might be of use to you also.
    http://cpn.canon-europe.com/content/education/technical/custom_functions_for_underwater.do
    Stew
  8. Thanks folks would like to hear more thoughts, so the concensus so far is for focus lock on AF? Just FYI I use a Canon T2i/550D. WOnder if theres a facility for this. Housing is Aquatica btw.
    Gavin, You can use a 18710.1 focus gear with the EF-S 60mm f/2.8 USM Macro, unlike the older non USM lens, the USM lens lets you override the AF without endangering the lens focusing motor. (just leave the lens in the AF position)
