Can I stack UCL-165 M67 with UCL-165AD using 10Bar Inon AD To M67 Mount Adapter?
Started by dkayuk ·
  1. Hi all
    I've recently upgraded my u/w kit to the Olympus EPL3 camera & PT-EP05L housing. For now I will be using the EPL3 kit lens (14-42mm). Also I bought the UCL-165 M67 macro lens. From my old Olympus compact camera u/w setup I still have the UCL-165AD macro lens.
    There is an adapter "10 Bar Inon AD To M67 Mount Adapter" which can be used to "attach the lens to a standard 67mm threaded lens port on a housing". Can it also be used to stack a UCL-165AD with a UCL-165 M67 lens?
    ie I would have : PT-EP05L housing --> UCL-165 M67 --> 10BAR adapter-->UCL 165AD
    Has anybody tried this and if it works, are the results any good?
    If this doesn't work I can sell the UCL-165AD on ebay :)
    thx
    David
  2. Not sure!
    Edited by Alex_Tattersall
  3. It is worth a try, many people stack FIT style diopters. Guess you will have to be within 2-4 inches of the subject to get focus.
  4. I have the 10bar adapter myself with a pair of AD mount macro lenses attached direct to the olympus macro adapter on my EPL-2 and that works fine. Seem to remember trying the AD mount lenses plus adapter on my fiance's EPL3 directly but getting some vignetting issues, though this may not be a problem with the 165 screw in first as you describe.
    Mooseman
