Underwater Ikelite housing body for canon 7d...UK Based
Started by natz ·
  1. Ikelite underwater Housing for Canon EOS 7D (body only)
    still in warranty only 8 months old , used only a handful of times, for surf photography. I have the spare parts it came with.
    I am based in the UK in windsor/LONDON (would prefer to meet in person, or will also post on ebay if shipping is required, which will be at extra cost)
    This unit sells in the uk for £1300 approx.
    im looking for £1050, its nearly new so price is fixed.
    THANKS
    below is the spec
    http://www.ikelite.com/web_two/can_7d.html
    Depth rating: 60m
    Controls for all camera functions exceept multi-controller and flash pop-up. Extension lever on back panel gives ergonomic movie start/stop control.
    Interchangeable port system.
    Port is supplied separately.(Port choice depends on lens to be used).
    Super-Eye long eye-relief viewfinder optic allows full frame viewing with diving mask. eTTL2 conversion circuitry provides full TTL operation with Ikelite DS-series substrobes. Two substrobes can be triggered using a dual sync cord.
    Exposure compensation buttons on rear of housing gives ±2 EV control range in TTL mode, or 8 manual settings in ½ EV steps.
    Non-Ikelite strobes can be used in manual mode only (with appropriate sync cord).
    Dimensions SLR-DC: With tray: 13.25"w, 8"h, 6.5"d. Without tray: 9.5"w, 6.75" h, including knobs.
    Weight: ~3.25Kg, 7.15lb without port. ~3.6Kg, 8lb with port.
    Buoyancy: slightly negative (depending on port).
