Need help with 2 ID
Started by Abucs ·
Need help with 2 ID
  1. Hi guys,
    1) Need some help here. Is this a coral or a some kind of critter?
    The hole actually closes up when I went near to it and reopens when I back out.
    2) Is this a newborn nudi or some species?
    editted
    Sorry if the photos are of poor quality.
    Edited by Abucs
  2. Hi Abucs,
    please refer to- http://wetpixel.com/forums/index.php?showtopic=17763 Extra info from you will help the experts to track your finds down.
    Here's a couple of guesses from an enthusiast to get you pointed in hopefully the right direction.
    Your first one is an Ascidian or Sea Squirt.
    The second image has a number of possible things in it. There is the feathery crown of a Tube Worm(what you may have mistaken as Gills of a Nudi?)
    The orange tentacles in the image look like feeding tentacles of another worm, we have one off the coast of southern Australia with very similar looking
    tentacles, Cirriformia cf filigera, though yours could be some type of Terebellid????
    Jim.
  3. The photos are fine but it would help if there were larger. Jim's right about the sea squirt & the tube worm (probably family Sabellidae). I suspect the "orange tentacles" are branches of a red seaweed rather than worm bits.
  4. Hi Abucs,
    please refer to- http://wetpixel.com/...ic=17763 Extra info from you will help the experts to track your finds down.
    Jim.
    Thank you very much Jim for the link and identification.
    Honestly, this is my first time spotting it.
    Found it at Tulamben.
    Thank you too Leslie!
    I also changed the photo to a larger one. Hopefully it helps.
  5. Much better size, thanks. The orange bits are definitely a seaweed. I'm still not sure about the white thing - either sponge, bryozoan, or tunicate.
