Is there anybody here using the new SANYO ENELOOP XX Batteries? Are they better than the regular ones?
SANYO ENELOOP XX Batteries? Anybody using them?
Started by haring ·
- 7Posts
- 7Replies
I use them in my Inon Z240 flashes and they seem to work great. They have more rated capacity however I have yet to exhaust them so I can't say how much more they have in the real world.
I've been using the XX in the backplate of my L&M housing. I used 1 set of four, pretty much running them down everyday, recharging them over night, using again the next day, since November last year. Until about two months ago everything was really good, and they definitely had more lasting power than the regular, lasting three hour long dives or more, compared to two hour long dives for the regular. But now they only last between one and two hours. Maybe one is bad, maybe they all have gone bad..it says they should give 500 charges, compared to 1000 for the regulars, but it may be less than that. They are great when new though.
I've switched to another set that I bought at the same time but hadn't been using and all is good again.
Yes, I use them in my Sea&Sea flashes! I like them too. They last longer than the normal ones, can't say anything negative so far. I have them since one year now, still very satisfied.
br,
zelko
They test out quite nicely compared to normal eneloops (the 2000 mAh ones) and if they start to not charge properly, try running them through the LaCrosse type charger on a refresh cycle. I haven't had to do that with the XX versions yet but with the older style the refresh cycle takes them from 1700 mAh (after a few hundred charge cycles) back to 2000 or so.
Bill
Thanks!
I guess they die sooner than regular batteries. This makes sense because Sanyo indicates that they can be recharged only for 500 times. But they still should last for three hours after being recherge for 50-70 times... I think I will get the regular eneloopes....
br,
zelko
Thanks!
....with the older style the refresh cycle takes them from 1700 mAh (after a few hundred charge cycles) back to 2000 or so.
Bill
Good to know!
