A snippet from a 10 day KOmodo liveaboard
Started by stewsmith ·
  • 13Posts
  • 13Replies
  1. Now that looks awesome!!!
  2. Really cool!
  3. Nice video indeed!
    Could you give us some info on the video setup used?
    Bye
  4. Nu uses a 7D in Nauticam box ( sorry alex ) 10-17 for wide angle behind a mini dome and 100mm IS for macro and a Subsee +10 for small critters. Sola 600's for lighting
  5. Thank you so much Stew for sharing my work:)Thanks for show me your brilliant stuff on the boat too.See you again in the Ocean:)
  6. Nice video indeed!
    Bye
    Hi!My video setup
    Canon 7D in Nauticam
    Wide-angle setting: Compact dome 4.33" Nauticam ,Tokina 10-17 fisheye with Magic filter.
    Macro setting : Canon 100mm Macro L ,Subsee+10,Light SOLA 1200 Video x2 ,U/W Tripod Xit404,I maneuver focus by manaul focus gear.
    I shoot in 1080p 30 fps but export movie to 25 fps.
    Cheers:)
  7. Wow Nu, you really nailed that one. Great work! And what an amazing variety of marine life for one liveaboard.
    Did you use a tilt shift lens for your opening?
  8. Wow Nu, you really nailed that one. Great work! And what an amazing variety of marine life for one liveaboard.
    Hi!Nick.Big thanks
    The opening I shoot with normal wide-angle len but I use effect from Crumplepop.com "Shrink Ray"
    That one is tilt-shift effect quite nice one:)
  9. Nu, what depths was this shot at? Particularly those deeper parts when the image is more dark blue, and the reds are getting funky pink :)
  10. Nu, what depths was this shot at? Particularly those deeper parts when the image is more dark blue, and the reds are getting funky pink smile.png
    Hi!In the beginning part the beautiful reef shot I shoot on shallow depth between 3-8 m but the schooling fish shot was deep about 20-30 m.
    Usually I have no funky pink rock problem with shallow depth but when go deeper sometime I can see that problem too but I try to re-do manual white balance adjusting
    a few times and look at the result in live-view LCD then shifting white balance little bit :)I think DSLR vdo has this funky pink rock less than camcorder :)
    Yep! :)
  12. Just a little bit better then totally awesome, loved it.
