Sea & Sea MDX300 for sale with lots of extras
Started by wcs563 ·
  1. Sea & Sea MDX300 with dome port, w/ neoprene cover, macro port (never used), gears for Tokina 10-17mm fisheye zoom, Nikkor 12-24mm zoom (and port ext. ring and +2 diopter) and the Nikkor 105mm macro lens respectively. Also included is a custom designed and fabricated for this unit out of titanium, a bracket for tripod mount and dovetail bases on the bottom of the rig, by DES Corp. Bought new in January 2010, maybe has 100 dives. Never a problem, well maintained by an owner who has had housed cameras since 1996, without a flood, ever. No issue with unit or manufacturer, just wanting to upgrade. Very fine equipment. Body and port caps included as well as all documentation and original boxes. You can check out many of the images captured on my website: http://www.wrightcreativeservices.com or check out my albums on Facebook under my name: Dan Wright. Many other pieces and parts available for TLC and Ultralight arms, Ikelite strobes and mounts, just let me know what you need, I probably can hook you up at a decent price. Problem solver here, we can make your system work! Thank you for checking... $2700 call me at 917-617-4536 Note that I added photos, but the exceptions in the sale are the Inon swivel finder is not included, I illustrated the standard finder laying next to the housing, and the 10-17mm Tokina lens and the Nikkor 105mm lens. The gears on the lenses are what is for sale only, not the lenses. I will also throw in the four dovetail bases which are on the rig currently and in the photos.
    Edited by wcs563
  2. Here are a couple more images, including the custom designed and titanium fabricated tripod adapter and dovetail base mounts for the bottom of the rig. Very useful for turned the rig vertical, and mounting the strobes on either side of the unit as normal, not top and bottom as you would do if you couldn't change strobe positions. Also, you can mount four lights of course if you wish on the dovetail bases. Designed and constructed by DES corp, Union, NJ.
