which wide angle zoom should I get?
Started by JohnA ·
  • 12Posts
  • 12Replies
  1. I presently have a Nikon 10.5 on a D80 and Aquatica housing but think I'd like a wide zoom instead sometimes. I'm considering the Tokina 10-17, as well as the Nikon 10-24, and Nikon 12-24. I want something that will serve me well when I upgrade my body and housing in the future. I would be greatfull for any advice or opinions on these or something else I might want to considder as well.
    I also have a Sigma 17-70, and a Nikon 60 micro for other situations. I generally use 2 strobes
    Thanks- John
  2. I would go with the Tokina 10-17. Now all 3 lenses you have listed are DX lenses. I assume you would upgrade to another DX system.
    Kirk
  3. I used sucessful the Tokina 12-24 mm rectiliear wide angle on my D90 and D7000, but this lens need a big dome - or special - dome
    to get sharp corners. This lens is a DX lens, so you can't use it on a FX camera in FX mode but she works very good on a DX camera
    and this lens is very useful for topside shooting as well as she don't distort the picture.
    Chris
  4. Thank you both for the input. Hadn't thought too much about what I might upgrade to other then something with a bigger screen and autofocus video. Probably won't do that till 2014 or so. I use an 8" dome presently. Is there much diference in the image quality between the 10-17, and the 12-24 Tokina's? Kind of think that since I have the 10.5 prime lens, that the extra range of the 12-24 might be more usefull although the 10-17 seems to be really popular. Is there a lens that would serve me well presently, and still be a good one to have if I did wind up getting an fx camera? sort of thought I'd end up getting a d7000 or whatever replaces it by then, but figured I look into my next set up more when the time comes. Sounds like the the Nikon brand lensees aren't necessarilly any better, or am I reading too much into this?
    Thanks Again - John
  5. Soft corners with tge 12-24, I use a +3 diopter with it and that helps. Having said that, I have both the Tokina 10-17 and 12-24. I use the 10-17 95% of the tine.
    Kirk
  6. And I use the 8 inch dome port and the +3 diopter was Jean with aquatica'a suggestion since I use their housing.
  7. Hi
    i use the Nikon12/24 W/A lens with wide dome port which approx 140mm , with a 35mm extender & a +4 diopter.
    i get very sharp corners. i also have 10/17Fe & 10.5Fe both very good I would say the 10.5 Nikon is slightly sharper.
    i think all lens have their place when to use them.
    Regards,
    Andy
  8. Sounds like the nikon 12-24 might be better then the tokina 12-24 in the corners, however the tok 10-17 seems to be a solid performer in most everyones tool box. Sort of makes sense in that I'd think it would be easier to get good optics in a range of 7 rather then 12. Havent tried a diopter yet. I know there's a depth of field loss, however in wide I'd think it more manageable. I could certainly use it sometimes with my 60 as well. I like my 10.5, but in a close situation with lots of divers a zoom could be handy to have I've found.
    I too am very happy with the suppourt I've gotten from Aquatica. Basd on that alone I plan on sticking with them when I do upgrade.
    Thanks- John
  9. I have used both the 10.5mm Nikkor FE and the Tokina 10-17mm. I mainly shoot the Tokina at 10mm and prefer it over the 10.5mm as it feels less distorted and a fraction narrower in its field of view (Tokina @ 10mm vs Nikkor 10.5mm). The Tokina is more verstaile lens as it can used very successfully with shooting video on a DSLR and also CFWA stills with a TC and mini dome combo. You often find those that have the 10.5mm and the Tokina 10-17mm sell off their 10.5mm due to lack use.
    But if your after a rectangular wide angle zoom lens and and excellent topside WA lens there is also the Tokinas 11-16mm.
    Regards Mark
  10. Wow!. That's a pretty compelling review. Topside I often seem to use a high end point and shoot.
    I very much apreciate everyones input. It's really helped me sort through some of this. I've had some good results with my 10.5, but sounds like there won't be a sacrafice with the 10-17. That's reassureing.
    Thanks Again - John
  11. I've had some good results with my 10.5, but sounds like there won't be a sacrafice with the 10-17.
    You will sacrifice a little optical quality for flexibility in use, but almost no-one seems to regret this.
