need some help S&S MDX-D300 and port combos and use cases
Started by bfdc ·
  1. Hi....doing some upgrades and considering expanding use cases for my existing Nikon D300/S&S MDX-D300 setup and need some confirmation of port/extension combos before I start spending money.
    I have Nikon 10.5mm and Nikon 12-24mm lenses. I have the S&S NX Fisheye Dome port (acrylic, large dome, NOT compact)
    a) CFWA or WA Macro
    I would like to put a teleconverter behind the 10.5mm to try some of really cool "macro" shots that you all have been doing. By itself, the 10.5mm works great with my NX dome. I assume if I put a Kenko 1.4TC behind it, I will need to put a port extension on the NX dome. Is that true? If so, which one? One educated guess said it looked like the S&S SX extension would do the trick.
    Can anyone confirm or let me know what they use?
    b) Improving Performance of 12-24mm:
    As many have noted, the 12-24mm seems to have soft corners when use without "aids" in the NX dome. I have searched, but I can't seem to pin down a consensus over what combination of port extensions and/or diopters are needed.
    -Port Extension Only (and which one)?
    -Diopter Only (and which one)?
    -or port extension and diopter combo (which ones?)
    I have seen suggestions of SX extension only/no diopter; I have seen 40mm extension w/ +4 diopter; and I think a +4 or +2 diopter only.
    Any thoughts? (I just hope then answer isn't "any of the above...maybe") ;-)
    thx for your time
    Paul
  2. bump!
    I know this is old, ancient, obsolete system, but can anyone remember what they USED to do? ;-)
    in the meantime, I did order a +2 and +4 B/W diopter for the 12-24mm - the least expensive experiment for that lens. Though I may have to do some North Carolina November pond diving to see what works. BRRRRRRR!
    thx for any further info you can provide
    Paul
    a) CFWA or WA Macro
    thx for your time
    Paul
