RAW vs JPEG
Started by apete ·
RAW vs JPEG
  1. RAW vs JPEG
    Hello friends!
    I just read the RAW vs. JPEG article…
    Reading the manual of my Olympus C-5060 Wide Zoom:
    RAW: 8MB
    TIFF: 16MB
    JPEG: 4MB (Best Quality)
    When I shoot RAW the camera is busy for more than 10s after each shot. Sequence-shooting I can do 4 shots, but then the camera is busy for 40-50s - almost a minute!
    Sequence-shooting 4 JPEGs occupies the camera for roughly 8s.
    Now to the question: What takes time? Processing/storing one RAW file takes 5 to 6 times longer than one JPEG file, but file size is only double, and it is the JPEG file that is processed - not the RAW file.
  2. Let's talk about what happens when you take the two different kind of shots:
    RAW: the data comes off the sensor, through the A to D converter, moved into the buffer, and then MAYBE through some firmware processing - finally to be written to the card.
    JPEG: the exact same thing happens, but the file spends a LOT more time going through the firmware software processing. It gets cut down to 8 bits, curves are applied, as is WB, sharpening, hue/saturation, etc. Then it also runs through the JPEG compression algorithm. Does the same amount of info have to move to the buffer? Yes, I think so, but much less info goes from there to the card.
    Not having used or studied the 5060 the above is purely speculation on my part.
    I too was surprised to hear that your JPEGs are taking 1/2 as long to write as the RAW files - it should be much faster.
