Advice on manual focusing gearing Canon 16-35
Started by Tidalstream1 ·
  1. New to the underwater photographic side & Just looking to acquire a package based around a 5D Mk 11 and an Aquatica housing & all the other bits that go with it such as domes,ports,arms,strobes - not sure where the list ends !!
    But a question on the focusing arrangements for lenses on the Canon 16-35, I don't quite understand if I really need manual focusing gearing is this a necessity?
    Thanks in advance for replies......
  2. Hi Tidal,
    Long answer to answer your question: Your 16-35mm lens is classed as a zoom lens. You have a great compositional tool in that you can zoom in and out underwater, and therefore you have more options to play with re: field of view, composition, sunbject selection etc. on a given dive.
    if you want the ability to be able to zoom your lens underwater thro' the focal lengths of 16-35mm you will need a manual focus gear.
    Otherwise, be prepared to use your 16-35mm lens at one fixed focal lens every time you dive with it.
    i.e. you fix it at , say, 16mm- put it in your housing- and it stays at 16mm for the entire dive.
    If you are prepared to do this, it kinda defeats the purpose of taking your 16-35mm lens underwater in the first place! :-)
    Short answer: With a zoom lens, yes.
    Hope this helps :-)
    Edited by Damo
  3. Ah that makes a lot of sense now ! many thanks for your reply Manta - & some quality images on your photo stream, very impressive. Your macro shots would be the type of shots that interest me,although I guess its spotting the little critters initially!
    Ive been in the Philippines nearly 2yrs now & know that i'm missing so much by not taking advantage of an amazing underwater realm here.
    thanks once again :-)
  4. It's a zoom gear, not a focus gear (they fit to different parts of the lens) that you need. Using both can be a struggle in many housings.
