Flooded Sola - is there anything you can do?
Started by Alex_Mustard ·
  • 12Posts
  • 12Replies
  1. My Sola 600 went glug, glug today :-(
    It is a bit frustrating, as it is a sealed unit there is not much you can do to prevent something like this.
    Does anyone know if there is there anything that can been done? Or is it simply a case of throwing it away and buying another?
  2. Return it to your dealer to have L&M evaluate. The warranty is one year, but they are pretty good about these things. But from the UK that can get expensive...
    Jack
  3. And they are not cheap either... It is a sad paradox to see the "300 ft depth rated" lettering in the pic...
  4. I had one flood after a bit more than a year and L&M replaced it. Give them a call and see.
    Bill
  5. Bugger! Which model was it Alex?
  6. User error for sure ;)
  7. Thanks for the ideas. I will email them and report what they say. Flood was at 12ft!
  8. Just discovered L&M UK no longer exists.
    So I'll have to contact California. Not exactly convenient if I have to send the flooded "unfloodable" Sola back.
  9. Just discovered L&M UK no longer exists.
    Wow, I didn't know Stephen Mawle had closed shop...
  10. PM sent.
  11. Unfloodable is certainly relative. Most of the floods I've seen involve using mounting hardware that is too long and punches a hole in the bottom of the case...
  12. Sadly for Steven Mawle, L&M have changed distribution channels and are now using TUSA. I can put you on to them if you want.
