FS Nauticam Macro Port 87. Suitable AF-S Micro Nikkor VR 105mm
Started by MarkD ·
  1. For Sale this Nauticam Macro Port. It has an external 67mm thread if you want to add a diopter for super-macro and also has an accessory cold shoe for fitting a focus light.
    It will suit the Nikon 105mm VR macro lens. I have also used it successfully with the 60mm micro Nikkor (you loose a little subject to port distance).
    I am selling as I now use the Macro Port 60 and add an extension when using the longer 105 lens to save a little on travel weight.
    The port is in first class condition having been used for perhaps 3 or 4 weeks diving and carefully looked after. No abrasions on glass or body. Comes with the O ring and protective front and rear caps. Original box not present but I will pack well.
    In UK. Cost £GB 150 + P&P. This is almost half the UK cost new!
    Mark
  2. SOLD, Thanks,
    Mark
