Nauticam Flip Diopter holder with Subsee diopter
Started by decimal86 ·
  • 9Posts
  • 9Replies
  1. folks
    i have found that my Nauticam holder will not accomodate a Subsee nor Inon wet lens. it will not screw all the way to the stop.
    anybody else has this problem? thks for your help
  2. I haven't had that problem. My subsee screws perfectly into both my Nauticam macro ports.
  3. Just to second that. I have used Subseas with the Nauticam flip bracket with no problem too.
    Adam
  4. hmm is it true there are 2 Nauticam manufacturers? one in Hong Kong and in the US? mine is genuine but it will not take a Subsee nor Inon...
  5. I was using a Subsee on my Nauticam port on my NA-EM5 this afternoon and Eleonora was using it on her Nauticam port for the NA-D7000 on the same dive!
  6. thks folks for the valuable info, i have sent my holder in for a replacement. luckily i did not dive with it or else it would have been another issue altogether. i just could not believe that it could not take a Subsee nor an Inon.
  7. Hi Guys, May I ask, does the flip holder work with a flat port?
    Phil
  8. Yes - no problems.
  9. I just ordered a nauticam housing for my G15 but am trying to decide if I should get their flip holder to use with my subsee diopters or have reefnet make me a new adapter for it instead. Price should be the same.
    I've heard that the nauticam holder screws into the 67mm thread on the port which would mean that I can only use my macro diopters with it. Is this how it works?
    Since the subsee adapter goes around the outside of the port I still have the ability to add or take off other 67mm wet lens as needed while leaving my macro in the flip out position.
