Travel bag- which size?
Started by Fasando ·
  1. Hey, im going to get a travel bag for my photo equipment(which atm include an ikelite ds 125 strobe, ULCS arms and clamps, ikelite housing, ikelite 6" dome, and soon going to add another strobe, 60mm and a flat port),, I dont know which bag size i would need, could i squeeze them all inside the pelican 1510 with padded dividers? would it be too cramped up? or should i get the bigger pelican 1560 with padded dividers for more room? Any input? would be glad to see pictures of how people pack their equipment
  2. I used a Pelicase 1600 for a similar rig, if you use bubble wrap instead of the foam you can get more small stuff inside BUT,
    if not packed tight things may move around and can get damaged. The foam or divider helps greatly to keep those expensive things in place.
    Chris
  3. I used to be a fan of the Pelican cases but now I really like the Think Tank Airport and the LowePro Pro Roller. I have one of each because we bought a LowePro for my wife's equipment and the Think Tank for mine. Both will pack everything you need, fit more because of padded dividers instead of foam, are light weight and the roll.
  4. There are places in the world where a high-end protective bag just screams out "Expensive stuff in here! Come and see!!"...
  5. Well,
    the question was if OP posters gear fit in a Pelicase.
    I never ship my Pelicase as it is,
    it is always in a old, torn 08/15 suitcase (actually you can see the handle of it)to avoid attracting curiosity.
    The cameras, lenses, chargers, disks, laptop gos in a LoewePro Photo backpack and the have to fight with me to get it.
    Chris
  6. Indeed, when i travel ill do that, but still which size should i get? i got Lowepro photo backpack, which i can fit my camera gear and lenses and etc, so would i need the bigger 1560 with padded dividers for my gear or is the 1510 sufficient?
