Ikelite 7d underwater housing with 8" dome lens port
Started by natz ·
  1. Ikelite underwater Housing for Canon EOS 7D with
    IK5510.24 Port Body
    IK5510.45 8" Dome Port with Shade and Cover (In warranty) (http://www.ikelite.c...port_canon.html) here you can check which lenses fit this dome
    Spare Silicone Lubricants
    Spare O ring
    used only a handful of times, for surf photography. I also have all the spare parts the housing came with.
    Excellent piece of kit.. can use nearly all the functions on the camera when in the housing, not like other housings that limit.
    Im on Maui until around the 3rd Jan , after that i will be on Kauai so contact me asap if you are interested could also meet in california
    $1750
    below is the spec for the housing
    http://www.ikelite.c...two/can_7d.html
    Depth rating: 60m
    Controls for all camera functions exceept multi-controller and flash pop-up. Extension lever on back panel gives ergonomic movie start/stop control.
    Interchangeable port system.
    Port is supplied separately.(Port choice depends on lens to be used).
    Super-Eye long eye-relief viewfinder optic allows full frame viewing with diving mask. eTTL2 conversion circuitry provides full TTL operation with Ikelite DS-series substrobes. Two substrobes can be triggered using a dual sync cord.
    Exposure compensation buttons on rear of housing gives ±2 EV control range in TTL mode, or 8 manual settings in ½ EV steps.
    Non-Ikelite strobes can be used in manual mode only (with appropriate sync cord).
    Dimensions SLR-DC: With tray: 13.25"w, 8"h, 6.5"d. Without tray: 9.5"w, 6.75" h, including knobs.
    Weight: ~3.25Kg, 7.15lb without port. ~3.6Kg, 8lb with port.
    Buoyancy: slightly negative (depending on port).
    Edited by natz
  2. Hi, I am interested at $1450 which I think is fair price.
    John
  3. Still have this available?
  4. would like to know if this is stil available as well.
    thanks
    Edited by josh80
