need some help w/ flashlight diffusing for video
Started by lehua808 ·
  1. Hello all, i have a couple 220lm compact Intova flashlights that i would like to use as video lights for gopro videos. It would be an ideal compact setup for me. Is there anyone who can help me figure out a diy diffuser setup for the flashlights? the beams are way too tight and concentrated to use for video and it tends to blowout the subjects easily. I'd like to make something to spread the light a little wider and softer. Maybe something like a piece of flourescent lighting diffuser panel, would that work? Any tips I can use to accomplish this would be greatly appreciated! Thanks!
    here's the lights that i have
    http://www.intova.net/products/the-intova-torches/
  2. When you make the beam wider to get rid of the hot spot then you will have no light anymore.
    For daylight use even 4000 lumen @ 120° are not enough to illuminate for more than 50 centimeters/2 feet.
    Your lamp will be barely enough for night dives but as the GoPro has a almost 180° FoV it will still leave a "hotspot" because f the extreme angle
    Anyway, you can stick a white adhesive on the lens, put a white translucent plastic bag over the lens,
    search for piece of white lexan or plexiglass and find a way to fix it on your lamp and it will make the hotspot softer.
    Chris
  3. thanks Chris, I'll try the lexan, i have a bunch of 1/8" sheets laying around. Maybe i'll try wetsanding it w/ 1200grit to make it translucent. I only need the light to illuminate under tight ledges and small caves/holes mostly to video inside lobster houses. The rest, natural light is fine. I'm a freediver and thus the ultra-compact gopro setup. I'm just trying to figure out the smallest lighting rig i can to minimize drag on the trip up/down.thanks again!
  4. Old milk jugs (the plasic ones) work fine, just Velcro them on but they will not be very bright at the end of the day as Chris points out.
    Bill
