NIKON d100 HOUSING-ADVICE
Started by COSMOFISH ·
  1. NIKON d100 HOUSING-ADVICE
    I WOULD LIKE TO SWITCH FROM MY AQUATICA 90 FILM HOUSING TO A HOUSING FOR MY NIKON D100. i HAVE PORTS: 8" DOME, FLAT PORT FOR 60MM, AND EXTENSION RING FOR 105 NIKON. I USE 2 IKELITE 100A STROBES WITH A DUAL SYNCH CORD. (CIRCUITRY WAS UPDATED WHEN I RAN THESE ON A LIGHT & MOTION TETRA 5000 FOR THE COOLPIX 5000). IN ORDER TO KEEP COST DOWN A LITTLE BIT, I HAVE LOOKED AT THE AQUATICA HOUSING AND THE LIGHT & MOTION TITAN SO I CAN USE MY AQUATICA PORTS. iF i GO WITH L&M I PROBABLY CAN USE THE 100A'S SINCE THE ROC CONTROL WILL ADJUST FLASH OUTPUT MANUALLY. IF I GO WITH AQUATICA I DON'T THINK I CAN USE MY STROBES, I THINK I WOULD HAVE TO BUY 2 DS-125'S OR?, A MANUAL CONTROLLER AND A TTL SLAVE (DO THESE REALLY WORK?). IF YOU CAN OFFER ANY ADVICE CONSIDERING COST, RELIABILITY AND GENERAL DIRECTION HERE PLEASE LET ME KNOW. I DON'T WANT TO MAKE THE WRONG CHOICE. I THINK I'VE THOUGHT OF EVERYTHING
    THANKS!!!
    COSMOFISH
