HELP!! Which Strobe??
Started by Blaze ·
  1. HELP!! Which Strobe??
    I have a Oly C750 UZ in a PT-018 housing, plus an Epoque wide angle lens. I am now looking at the options, makes & models of a strobe set up.
    I need an simple set up (as I am a dweeb :oops: ) and have had a suggestion made that I should consider two video lights instead of a strobe, or one strobe one video light. My camera does not have a "focus beam" for night shots or shooting in dark places. I have never used an external flash set-up before so the easier the better. I am lost with which brand to purchase?? Inon, Ikelite, Epoque??? It is all so confusing. :?
    Any assistance would be greatly appreciated.
    Thanks - Blaze
  2. Hi Blaze,
    The Inon strobes come highly recommended. I use an Inon D-180 myself and it is small, powerful and easy to use.
    I also use a Ikelite SS200 strobe and it is a really great strobe so I'm sure their digital strobes are great as well but haven't used them. (Not really fond of the extra controllers).
    For a much better comparison of strobes:
    http://www.digitaldiver.net/images/strobea...rticlescrn2.pdf
    Good Luck
    /Stefan
  3. Thanks Stefan for the web link. Great info!! Happy diving - Blaze
  4. Hi lidde,
    Do you know the difference between D180S and D180?
    Thank you,
  5. Yes, I believe so.
    The D-180 has a full guiding light (bulb) while the D-180S only has two led lights (bright dots). The D-180 has 4 manual settings for strobe output together with External Auto Mode, while the D-180S only has the External Auto Mode.
    Apart from that I believe the two strobes are identical.
    /Stefan
