What diopters in Nauticams Smugmug album?
Started by swgdesign ·
  1. Can anyone tell me what diopters were used in the gallery for the RX100 shots here?
    I am about to upgrade to the RX100 as an interim to housing my D7000 next year or the year after and I would like to know what diopters were used....
    THanks
    Simon
  2. I'll try to confirm, but I believe it was the +10 Reefnet Subsee. The more power the better with RX100.
  3. As far as I recall nauticam uses +10 subsee for their shots that by the way are also cropped
    The rx100 has a pretty large capture area
    http://interceptor121.wordpress.com/2012/12/02/sony-rx100-tips-for-underwater-video-part-7-macro-shots/
    Compared to other compact cameras
    The camera doesn't have a macro mode and on land it works well until you are 2" away from your subject
    In water though it struggles to focus on small items and you need to sort back further to make it work
    So at least a +5 is needed just to be on par with other similar cameras and a +10 or even more is required for super macro
    As far as I can see the nauticam shots are also cropped
  4. As far as I recall nauticam uses +10 subsee for their shots that by the way are also cropped
    http://interceptor12...-7-macro-shots/
    so, if I'm using Epoque dml-2 will I get reasonable macro?
  5. so, if I'm using Epoque dml-2 will I get reasonable macro?
    It is always difficult to say without testing if you look at the specs the epoque is a 8.4 diopter so it should work well for regular macro
  6. Yes, these are taken with Subsees
