ikelite sync cord TO hotshoe, for over-water use ?
Started by the_dragon_no1 ·
  1. I got a DS51 and thinking of useing it over water from time to time, also have the single ikelite sync cord.
    Possible to get a adapter of some kind, from ikelite 5pin TO hotshoe ?
    Or, safe to make one on my own if i get a ikelite connector and a hotshow connector.
    Ronni
  2. Probably not,
    as the hot shoe inside the housing passes usually/mostly trough Ikelite TTL-Controller.
    You can trigger the strobe shortening the 2 pins, but the strobe will fire a full dump (or the other 5 power settings)
    and you need to use your camera most likely manually.
    You could get the pin layout of the strobe and the hot shoe of your camera, buy 2 cables and connect them manually
    to trigger the strobe without the housing.
    Chris
  3. There is also this warning in the manual about above water use.
    • Do not continuously fire the strobe more than 15 times above water in rapid
    succession. If this does happen, allow the strobe to cool down for at least 10
    minutes.
  4. Okey i see chris, thanks.
    Gerard, hmm, i haven't read that.. but i have seen some posts online about people testing this, with 200 something flashes rapid, and no problem.. But i'll check it out before i might burn anything :)
