Internal dome reflections.
Started by aorr ·
  • 20Posts
  • 20Replies
  1. I have the Nauticam NA-800 housing with a Nauticam 8.5" acrylic dome and I've been suffering some concerning internal reflections from the rig. I've read on here that most of the reflections that people are getting are a result of the internal flash "showing through" to the dome and reflecting. I'm using an Ikelite hotshot connection so that's an impossibility for my particular case. I didn't notice any other suggestions on the board which might be causing it other than strobe placement. I have tried moving the strobes both fore and aft of the dome and pointing them away. I still seem to get some portion of reflection.
    I was curious if there are any other factors that may be leading to this issue that I haven't thought of? Obviously everything in the dome is black in color so there isn't any white paint that could be causing them. I've attached a sample to illustrate the type of reflection I'm seeing. I also notice this type of reflection when aiming the camera into the sun. Obviously it's something to do with light reflecting from an outside source.
    I've only used a Nikon 16-35mm f/4 lens on the camera with the dome so that could be a partial cause/effect of the reflections. I have a UV filter on the front as well.
    In the meantime, one quick-fix I could do is shoot in DX mode which would effectively crop most of the reflection out...but of course I did not buy the D800E to shoot it in crop mode. :-)
    Thanks for your help!
    -Andy
  2. I have seen this with my 8" dome too shooting ambient light.I will be curious to see an answer I don't have one.
  3. I do mostly cave diving photography, and I get this when divers face their bright HID primary lights (or LED or whatever technology...) at the camera.
    The light comes in and reflects off the front of the lens, which then bounces off the inside of the dome and back into the sensor, showing up in my pictures.
    Some people take thin velvet type fabric and put it on anything on the lense that's not part of the glass optics, but I also don't like bright lights blowing out the image so I just train models to shine their light to the side, and it gets rid of it most of the time.
  4. I'm reluctant to try and shoot without my UV filter since I'll be trying an underwater green-water filter this weekend for ambient light photography. That will require a filter to be on the front element so let's hope that's not the issue. Although, in the strongest-reflection picture it appears as though threads are showing in the reflection. Not good!
    I'll be at Our World Underwater in Chicago next month so I planned to ask Ryan Canyon from Reef Photo about the issue. Maybe he can point me in some new direction for alleviating these.
    -Andy
  5. I notice that it's primarily your UV filter ring that is reflecting like this; presumably it has a relatively shiny surface on it? This is likely the main cause of the issue. Have you tried shooting without this UV filter?
    I have seen many people paint the shiny portions of their lenses with matte black paint to help alleviate this, especially lenses with shiny silver or gold rings on them. Since it's just a UV filter on the front, what do you have to lose by painting it matte so it doesn't reflect?
    Notice how in each of these images you are shooting into relatively strong sunlight? When enough light hits your lens through the dome, it reflects onto the inside of the dome. So if you can, avoid pointing your housed camera directly into strong light sources that you know will cause this reflection.
  6. Thanks for your thoughts, Moray Eel. I'll try looking into that with the UV filter.
    -Andy
  7. Hope it helps! Moray Eel is just my current rating, my forum handle is blaisedouros which provides a huge degree of anonymity given that it's nothing like my name. Swear ;)
  8. Hope it helps! Moray Eel is just my current rating, my forum handle is blaisedouros which provides a huge degree of anonymity given that it's nothing like my name. Swear wink.png
    Ha! Wow, can't believe I fell for that. Lol. Every forum is different on where usernames are shown and this one totally fooled me! By my ideology I would be titled "Hermit Crab" as well!
  9. Folks,
    This is a common problem when shooting into the sun at relative shallow depths. I think the first to post here on the solution was Stephen Frink a few years ago. A black sharpie can be helpful and people have tried flat black paint which can work. A good optically coated dome helps to reduce the reflections. Stephen posted a solution back in 08 using black flocked paper available from Edmund Scientific but they no longer show it as available. His article for Seacam on his solution is here. I’ve used black gaffers tape from Shurtape (CP-743) on the front of the lens which I think helps.
    If anyone has found a replacement for the black paper I'm sure they'll jump in.
  10. That looks like the stuff partner. #55 adhesive backed. Thanks!
  11. Excellent, I'm going to get some of this. It looks like it would be useful for a variety of photographic applications and projects.
  12. Great, thanks for the advise Steve! Can't wait to try this!
  13. I used to have a simillar problem when I first got the Nikon 10.5mm fisheye lens.
    Many of the Nikon lenses have a decorative gold ring and gold lettering on the lens barrel which seems to reflect the light and caused me the same sort of problem.
    I used a piece of black elastic which I stitched into a loop which fits around the lens barrel and covers the gold ring and lettering and seemed to solve the problem. It's cheap, easily available, doesn't mark the lens, stays in place inside the housing and can be easily changed between lenses.
    Hope this helps.
  14. Just use gaffer's tape aound the shiny parts of your filter. Gaffer's doesn't leave any residue.
    S.
    Edited by Stewart L. Sy
  15. I used indelible black ink. I first used it to black out the inscription round the front element of a macro lens I used because I was ashamed that people might have seen it was a 105mm Cosina I bought seconhand for $70. At f22, it was perfectly sharp!
  16. Good ideas. I'm going ice diving in a few days so I'll be able to test it out! Going to try and stick with gaffers tape to avoid some extra expenses with this first go-around.
    -Andy
  17. I've just got back from a southern Red Sea trip to find a lot of my images shot in the caves at St John's have reflection "issues". I was shooting a Sigma 15mm FE inside a Subal DP-230 port. Argh. Happily I have been able to PS/LR most of the problems out of the image. Annoying though.
    As Steve explained, for me too the issue was mainly in relatively shallow water (say around 5-10m) in darkish areas with shafts of sunlight hitting the dome. It looked brilliant. Apart from the internal reflections :aggressive:
    Thanks to Aussiebyron, Ronyx, Steve and others for the helpful ideas on fixing it....
  18. The problem with the Sigma 15 mm FE is the front part (around the glass) and not the outside part of the lens. Since that area it's not mat, when we try to do some backline shoots with the sun in the picture one can see the parallel lines in the reflection inside the dome (I use the Subal DP-FE).
    I'm surprised that not every people that use this lens doesn't have the same problem. Or maybe they still not noted it...
    Although in photos its possible to use PS or LR to fix it, a major problem is when shooting video. It will ruin completely the footage :-(
    Until now I wasn't able to find a good solution. I've tried to glue some mat tissue but it came loose. Permanent ink (like Edding 3000) is not mat enough. And since the lens is metal painted black, its not possible to sand paper that area either.
    Anyone have another sugestion?
    Thanks!
