metabones speedbooster
Started by Glasseye Snapper ·
  1. Hi all,
    I just checked in to see what people thought about the Metabones "speedbooster", announced with some fanfare a few days ago, and am surprised that it hasn't come up yet. I had for a long time thought this was such an obvious interesting tool that the fact it didn't exist must imply it can't be done. Now apparently it has been done. So why not earlier? There was some suggestion that it can only be done with mirrorless but I don't get that.
    Anyway, if you haven't heard about it just check dpreview or google it. It is basically a reverse teleconverter which demagnifies the image. The result is a larger FOV (you no longer need to apply the APS-C crop factor to the focal length) and a gain in apparent aperture.
    The first adapter will allow you to use Canon EF lenses for use on Sony APS-C NEX bodies, by applying a 0.71x demagnification, yielding a 1 stop speed gain. A version for m43 olympus and panasonic bodies should come later. These could have up to a 0.5x demagnification and 2 stop light gain. So my cheap but good 35mm F2 would become a 35mm F1 on m43. It don't think you get the shallow depth of field of a true F1 lens but the two stops of light will help negate some of the drawbacks of the smaller m43 sensor under low light.
    A potential counter argument for UW use is that without adapter you would use a shorter focal length m43 lens to get the same FOV as a FF lens, and shorter focal length normally translates to closer minimum focus (an UW advantage of m43 that is not often mentioned). But for lenses that can already focus close, like the 35mm F2 or 100mm macro, it should be interesting.
    If image quality is not affected, and that is the claim/expectation, then I would be very interested. Both to keep using some of my Canon lenses after a switch to m43 and to see what the extra light can do. The question is, will FF lens diameters fit into mirrorless camera ports?
    Bart
  2. I wrote to Metabones about a 0.5x adapter for M43 and they said they'll only be producing a 0.71x adapter, which for general use would be much better with NEX cameras. I think the most interesting use userwater for M43 could be adapting the Tokina 10-17mm FE, assuming the AF works reasonably and the optics aren't compromised...
  3. I also hear that they will make a version to translate old OM lenses with the same .71x factor. And surely there are a lot of older lenses Nikon, Canon, Sigma etc. to check in the UWA area.
    Frankly unless there is some older lens you can adapt and test I see the cost and size to be of little benefit.
    I only see a hole in the UWA to complete good MFT support in underwater use and I am sure it will be filled by some upcoming lenses... Everything is pretty much there already but the choice could be better!
    Edited by nudibranco
  4. quite promising indeed !! My 15mm fisheye Sigma with Canon mount may get some use on my OM-D afterall. !!
    I used to love its images on land with APS-C Canon cameras I had.
    And on M43 with the metabone adapter it should give similar focal length as the 15mm lens on APS-C...but with a 2.0 aperture!
    It would fit interestingly between the 8mm Pana and 12mm Oly M43 lenses with about a 125 FOV and much less barrel distortion than the 8mm FE lens.
  5. Can anyone with a mirrorless Nauticam housing and DSLR lenses check if the diameter for mirrorless housing ports will fit a DLSR lens, for instance the 15mm Sigma lens.
    Bart
  6. quite promising indeed !! My 15mm fisheye Sigma with Canon mount may get some use on my OM-D afterall. !!
    do they have a canon to m43 adapter?
  7. Yes the do have a CANON M43 speedbooster in the pipeline that says March for availability...
    Unfortunately very few lenses will make it into existing M43 ports.
    I tried the sigma 15mm lens and it will not fit the opening by a few mm sad.png
    And I am afraid most lenses will not fit...
    It may be better for NEX owners as the flange may be bigger I do not remember...
    UPDATE:
    The 15mm sigma does fit in the 12-50mm port. It just does not fit in the 4" semidome one.
    So I guess it does depend on the lens port combination although given that the 15mm lens is quite compact I still think there will not be many lenses that will lend themselves to UW use in the M43 platform...
