Silicone grease for Seatool Housing
Started by Aqua_soul ·
  1. Hi
    Can anybody advice me on what silicone grease can be used with the Seatool housings. I have a opaque main o-ring and a black o-ring at the front behind the port.
    Thank you
    Geo
    P.S. I obviously looking for a silicone other than their branded product as I think its ridiculously priced.
  2. I have only one lubricant for all my diving equipment + housings: christo-lube 111 or Tribolube 71. For static orings on the housing christo-lube 128 is even better.
    Pete
  3. Thanks scuba_d
    What is static o-rings?
  4. A static o-ring is an o-ring which seals between two motionless surfaces, like your main housing o-ring. All of the o-rings in an underwater housing can be lubed as static o-rings.
    Pete
  5. I also use Tribolube 71 for all my housing o-rings regardless of type of material. I use it on black, blue, yellow and red o-rings. It does not make the silicone ones swell.
    Elmer
  6. Thank you Pete and Elmer.
  7. Hi Pete
    Just would like to double check, is it 128 or 129 for the Christo-lube.
    I am not finding info on 128.
    Geo
