Intova Double Ball arms - diameter?
Started by Jock ·
  1. Hello,
    cannot find infos in the web about the diameter of the Intova arm BA6 (or BA10 etc.) - is this arm compatible with the ultralight system, i.e. ball diameter 1" ?
    The only infos I can find says it is compatible with the Intova system. The company itself does not list it on the homepage, so maybe it is a 3rd party product sold under their name?
    Jock
  2. Since nobody seems to know, I just ordered two of these arms. They are compatible with ULCS arms! I paid only 7.50EUR per arm, in the US they are even cheaper (6.95$ at Adorama). A rare gem - an item for uw-photography that does not cost a fortune!
    Jock
  3. Buy some extra o-rings - I picked up some of these and the o-rings dried out and split on me after only 1 trip; not sure if they're using really cheap rubber or what. I found a 20-pack of faucet washers at a home improvement store for like $2.50 that were just about perfect in both cross-section and "o" diameter.
  4. Since nobody seems to know, I just ordered two of these arms. They are compatible with ULCS arms! I paid only 7.50EUR per arm, in the US they are even cheaper (6.95$ at Adorama). A rare gem - an item for uw-photography that does not cost a fortune!
    Jock
    got two 8", will (intend to) use with net floats as they fit well in the central hole on most floats (10-12 mm). just worry about ball-rod joint. this arms are made not as a solid thing, alike ULCS (INON, Nauticam...)
  5. got two 8", will (intend to) use with net floats as they fit well in the central hole on most floats (10-12 mm). just worry about ball-rod joint. this arms are made not as a solid thing, alike ULCS (INON, Nauticam...)
    Hello Basileus,
    Could you describe your net floats? Do they suspend your camera in a fairly upright position by providing buoyancy from above?
    I fashioned a couple of suspending floats that clip onto my strobes. This is a good solution for me, since my strobe arms are very short - adding buoyancy in the usual way, by wrapping foam around the arms, makes it impossible for me to position the strobes the way I want. My floats give nearly perfectly balaced neutral buoyancy when used with two strobes and a heavy focus light, but maybe it would be even better to use nets, so that buoyancy can be easily varied to suit different equipment.
    John McCracken
  6. Since nobody seems to know, I just ordered two of these arms. They are compatible with ULCS arms! I paid only 7.50EUR per arm, in the US they are even cheaper (6.95$ at Adorama). A rare gem - an item for uw-photography that does not cost a fortune!
    Jock
    Hi
    Could you tell me the brand and where you get those arms ? I looking for another set and everything is so expensive !!!
